Hard plastic waterproof 2 part case with joint and wall mount for projects
Designed by Wyld Things in France
What is it? Hard plastic (ABS mix) case in 2 parts which screw together (4 self-tapping screws provided) with a moulded silicone joint for waterproofing (nominally IP67, but not certified). The front…
Read More…Hard plastic (ABS mix) case in 2 parts which screw together (4 self-tapping screws provided) with a moulded silicone joint for waterproofing (nominally IP67, but not certified). The front part is transparent, and the rear is opaque (cream coloured).
A set of holes allow air pressure equalisation while a gortex like filter (provided) stops water entry (alternatively the holes can be easily sealed with hot glue or silicone)
A specially moulded wall mount clips to the case and offsets it from the structure by 50mm and has either 4 screws or a keyhole mount to the wall.
Alternatively, the rear part of the case has openings for zip or other ties, and the possibility to screw into the case in 4 positions
Inside the space has an area designed to take a AA sized battery (with flying leads, no battery clip hw) and offsets/clip for a specific PCB size.
See the LoRaWAN sensor product for how it was used (PCB+AA battery)
For wall mounted/crate attach geolocation device product that was discontinued. These cases are the surplus stock - never been used or even taken out of the delivery boxes!
Its a nice hand sized case that is water resistant, and has the space to stuff in some project electronics and a battery. A properly shaped board could take full advantage of the space, and its deep enough to have a multi-PCB set pile...
Enter your email address if you'd like to be notified when Waterproof project case with wall mount kit can be shipped to you:
Monday is the day for package preparation and shipping.
1-9 | $5.00 |
10-99 | $3.00 |
100+ | $2.00 |
$12.95
$89.95
$119.00
