Splitter box with XT60 connectors for better cable management. Five connectors - One input, four output
Designed by Yoda_cz in Czechia
I made this box for distribution energy from my solar system. This system feed my DC device - 3D printer, computer and light. I hope it will find use for your needs as well. Case is 3D printed - SLA …
Read More…I made this box for distribution energy from my solar system. This system feed my DC device - 3D printer, computer and light. I hope it will find use for your needs as well.
Case is 3D printed - SLA print - Tough resin. The circuit board is double-sided and tinned on one side for better soldering. When soldering, a larger amount of tin was used for better current flow.
I fit original connectors from Amass. They are temperature resistant and solder very well.
also available 7 port version on my profile!
NOTE: if you want a different layout of the connectors, write a note in the order
Enter your email address if you'd like to be notified when XT60 Splitter box - 5 ports can be shipped to you:
$15.98
