Splitter box with XT60 connectors for better cable management. Seven connectors - One input, five output
Designed by Yoda_cz in CzechiaNo shipping info available.
I made this box for distribution energy from my solar system. I use one connector from side like input. Five top connector using for distribution energy for my device. Second side is output for next …
Read More…I made this box for distribution energy from my solar system. I use one connector from side like input. Five top connector using for distribution energy for my device. Second side is output for next splitter. This system feed my DC device - 3D printer, computer and light. I hope it will find use for your needs as well.
Case is 3D printed - SLA print - Tough resin. The circuit board is double-sided and tinned on one side for better soldering. When soldering, a larger amount of tin was used for better current flow.
I fit original connectors from Amass. They are temperature resistant and solder very well.
also available smaller 5 port version on my profile!
NOTE: if you want a different layout of the connectors, write a note in the order
Enter your email address if you'd like to be notified when XT60 Splitter box - 7 ports can be shipped to you:
