Z-Station Dual Protocol Z-Wave & Zigbee/Thread/Matter/BLE USB dongle
Designed by Z-Wave.Me in Switzerland
What is Z-Station? Z-Station is a Dual Protocol Z-Wave & Zigbee/Thread/BLE USB dongle that turns any PC it into a very flexible and powerful Z-Wave and Zigbee/Matter controller. It comes with sophist…
Read More…Z-Station is a Dual Protocol Z-Wave & Zigbee/Thread/BLE USB dongle that turns any PC it into a very flexible and powerful Z-Wave and Zigbee/Matter controller. It comes with sophisticated external antennas made by Linx Technologies Inc.
Z-Station comes with Z-Way - the best-in-class Z-Wave & Zigbee controller software that runs on your Raspberry Pi board. Z-Way has a nice UI and a very powerful HTTP API for your projects. You can also write server-side JavaScript apps to empower your home automation.
Z-Station is also fully compatible with Home Assistant and similar open-source projects.
Being a Z-Wave Plus certified controller Z-Station also supports Z-Wave Security S2, Z-Wave SmartStart, and Z-Wave Long Range technologies.
Z-Station 2.4 GHz chip comes with Zigbee, but can also be turned into an OpenThread or Bluetooth Low Energy device. You can also run Zigbee + OpenThread or Zigbee RCP + OpenThread + Bluetooth Low Energy firmware.
Z-Station is not just a simple USB dongle, it can become a Zniffer (with additional feature to be activated)
Compared to other controllers that are just a "black box", Z-Station and Z-Way software allows you to look inside the Z-Wave protocol, look into packets, Command Classes and inspect devices in many detail. At the same time, a very high-level and easy-to-use home automation engine is the heart of your smart home.
Z-Station also supports Home Assistant (including Home Assistant Yellow and Green), Zigbee2MQTT, OpenHAB, Jeedom, Domoticz, FHEM, Z-Ware, OpenZWave and other Z-Wave controller software.
Note that this version of Z-Staion is made for the United States, Canada, Argentina, Israel, Mexico, Caribbeans, and South America and Asia (908-920 MHz). Other frequencies are also available from other warehouse locations. Just drop a note in the order.
Enter your email address if you'd like to be notified when Z-Station Z-Wave & Zigbee/Thread/BLE USB dongle can be shipped to you:
1-9 | $126.00 |
10+ | $91.00 |
$138.00
$64.90
$84.90
$59.90
$706.00
$126.00
$273.00
$19.90
$12.99
