Z-Uno Shield in DIN-rail case or in sealed case is a universal and configurable Z-Wave device for your smart home
Designed by Z-Wave.Me in Switzerland
What is Z-Uno 2 Shield? Z-Uno 2 Shield is created to simplify your smart home installations. It can be configured to become a relay, a PWM-dimmer, a 0-10 V analog dimmer, a binary or analog sensor or…
Read More…Z-Uno 2 Shield is created to simplify your smart home installations. It can be configured to become a relay, a PWM-dimmer, a 0-10 V analog dimmer, a binary or analog sensor or even RS485/UART/1-wire bus converter.
Z-Uno 2 Shield is based on Z-Uno 2 but do not require soldering and programming.
Z-Uno 2 Shield is very easy to wire. It allows to connect many smart home actors and sensors out of the box:
We have created the Z-Uno Shield Configurator that will not only help you to wire your Z-Uno Shield correctly, but will also write the Z-Uno sketch for you. Most popular cases are covered by this tool. You can still modify the generated code or write your own sketch.
Z-Uno 2 Shield Configurator allows to create:
Z-Uno 2 Shield comes in a DIN-rail case or a Sealed case. Both include terminal strips for easy connection.
Download Z-Uno Shield Manual or check Z-Uno documentation
Being a Z-Wave Plus certified device, Z-Uno 2 Shield is the perfect companion for your RaZberry 7 Pro gateway. Z-Uno 2 is compatible with other Z-Wave controllers too.
We developed Z-Uno 2 Shield to simplify the creation of own device. Z-Uno is very powerful but requires some knowledge of schematics and programming. To help users and installers to work with Z-Uno we have created the Z-Uno 2 Shield. Z-Uno Shield is a multifunctional DIN-rail smart home device based on Z-Uno. It implements the most useful features of Z-Uno 2 and requires no soldering and no programming.
Compared to other existing Z-Wave devices on the market Z-Uno Shield gives you infinite possibilities to create your own customized device.
Note that this version of Z-Uno Shield is made for the United States, Canada, Argentina, Israel, Mexico, Caribbeans and South America (excluding Brazil) but it will also work in other regions. The frequency is changed via the user interface. 916 MHz and 868 MHz are both supported.
Enter your email address if you'd like to be notified when Z-Uno Shield - Universal Z-Wave device can be shipped to you:
$64.90
$84.90
$59.90
$706.00
$126.00
$126.00
$273.00
$17.50
$89.00
