Z-Wave.Me Multisensor 8-in-1. Works on Z-Wave or Modbus
Designed by Z-Wave.Me in Switzerland
What is Z-Wave.Me Multisensor 8-in-1? Z-Wave.Me Wall-mounted Multisensor is a Z-Wave Plus and Modbus RS-485 operating multisensor that contains temperature, humidity, light, motion, noise level, CO2 …
Read More…Z-Wave.Me Wall-mounted Multisensor is a Z-Wave Plus and Modbus RS-485 operating multisensor that contains temperature, humidity, light, motion, noise level, CO2 concentration and volatile organic compounds (VOC) sensors.
It can act as an environmental monitoring sensor at home, in rental apartments, hotels, offices, public places and schools.
Thanks to the IR blaster with a learning function MSW can also act as an A/V or A/C control.
Being a mains powered from 9 to 28 Volts this device acts as a repeater and extends your Z-Wave network.
The Multisensor can be connected using Modbus RTU or Z-Wave protocol. All the latest features Z-Wave Plus v2 with Security S2, Smart Start and Long Range are supported.
The multisensor case is made of plastic and is not waterproof, designed for use in homes and offices. For wall mounting.
Technical specifications: - Temperature: -40°C — +80°C (±0.5°C) - Humidity: 0 — 98% (±3%) - Light: 0.02 — 100000 lux - Noise level: 40 — 82 dB; - СО2 concentration: 0 — 5000 ppm. - VOC concentration: 0 — 60000 ppb. - Motion: up to 8 m, angle — 120° - IR commands sending and learning - Configurable buzzer (programmable melodies) - Two-color LED indication - Heated sensor designed for operation in high humidity conditions - Supply voltage: 9 — 28 VDC - Interface: Z-Wave or RS-485 Modbus RTU - Plastic enclosure with wall mounting option (83 x 83 x 21 mm)
Note that this version of Z-Uno Shield is made for the United States, Canada, Argentina, Israel, Mexico, Caribbeans and South America (excluding Brazil) but it will also work in other regions. The frequency is changed via the user interface. 916 MHz and 868 MHz are both supported.
Enter your email address if you'd like to be notified when Z-Wave.Me Multisensor 8-in-1 can be shipped to you:
$138.00
$64.90
$84.90
$59.90
$706.00
$126.00
$126.00
$76.54
$346.00
$250.00
