CC2538 + CC2592 ZigBee Raspberry Pi plug-in module. Direct connection to GPIO connector of Raspberry Pi (UART).
Designed by ZigDobby in United States of AmericaNo shipping info available.
CC2538 + CC2592 ZigBee Raspberry Pi plug-in module. Direct connection to GPIO connector of Raspberry Pi (UART). Module has an onboard CC2592 for range extension. Module configured to connect with ext…
Read More…CC2538 + CC2592 ZigBee Raspberry Pi plug-in module. Direct connection to GPIO connector of Raspberry Pi (UART).
Module has an onboard CC2592 for range extension. Module configured to connect with external antenna. Comes flashed with Z-Stack firmware 3.0.X.
The CC2538 is much powerful comparing with CC2530, up to 100 devices can be connected directly to CC2538 instead of 20 (CC2530). However, the number of direct children in a ZigBee mesh does not determine the maximum size of the installation. See also the zigbee2mqtt FAQ. Current version contains: • Direct connection to the Raspberry Pi • Z-Stack Firmware 3.0.x • High range thanks to CC2592 • Flexible placement through external antenna • Serial bootloader (SBL).
ZigDobby – company focusing on providing home automation solutions based on power efficient ZigBee protocol
Product is based off Cod.m module [GitHub] and adaptated to available components.
Result are distributed under CC BY-SA license here.
Enter your email address if you'd like to be notified when ZigBee CC2538+CC2592 coordinator for Raspberry Pi can be shipped to you:
Product: (1.00)
Documentation: (1.00)
Shipping: (4.00)
Communication: (4.00)
Evan | April 3, 2021
$16.06
$31.99
$9.00
$18.95
