CC2538 + CC2592 ZigBee USB dongle adapter. Flashable
Designed by ZigDobby in United States of AmericaNo shipping info available.
CC2538 + CC2592 ZigBee USB dongle. > - Powerful range extender C2592. > - Can support up to 100 direct devices (CC2530 can support only 20) > - Z-Stack Firmware 3.0.x, SBL bit enabled > - Can be flas…
Read More…CC2538 + CC2592 ZigBee USB dongle. > - Powerful range extender C2592. > - Can support up to 100 direct devices (CC2530 can support only 20) > - Z-Stack Firmware 3.0.x, SBL bit enabled > - Can be flashed without additional hardware > - Compatible with Zigbee2Mqtt
The CC2538 is much powerful comparing with CC2530, up to 100 devices can be connected directly, however number of direct children in ZigBee mesh does not determine the maximum size of the installation. See also the zigbee2mqtt FAQ. CC2592 extends distance up to 100m (in some cases up to 400m)
ZigDobby – home automation solutions. "Home is your friend"
Enter your email address if you'd like to be notified when ZigBee CC2538+CC2592 USB dongle can be shipped to you:
1-4 | $42.99 |
5+ | $39.99 |
$37.00
