Crystal and caps for your breadboard match Arduino, PIC, ATmega pinouts. 8, 10, 12, 14.7, 16, or 20Mhz.
If fiddling with crystals and capacitors falling out of your Arduino-compatible breadboard projects is your idea of fun, stop reading now, ok? I thought so. Annoyance and irritation suck, don't they?…
Read More…If fiddling with crystals and capacitors falling out of your Arduino-compatible breadboard projects is your idea of fun, stop reading now, ok?
I thought so. Annoyance and irritation suck, don't they? That's why you need these crystal+cap boards for your breadboarding.
The best part? The pinout matches ATmegas, ATtiny4313, some PICs, so they plug right in next to your DIP MCU on a breadboard. No jumpers needed. Crystal and capacitors are pre-installed; just add the 3-pin header.
They won't fall out either. The one on my 20mph, autonomous rover, Data Bus, stayed put even after crashing. Often.
Available frequencies: 8, 10, 12, 16, 20 MHz as well as 14.7456 MHz for generating a perfect 115200 bps.
Goodbye irritation. Hello fun.
Worth a try? Order and I'll send one as fast as I can. Buy more and save.
Designed, fabricated and assembled in the United States of America.
Enter your email address if you'd like to be notified when Crystal and caps breakout board can be shipped to you:
Alnoor | Sept. 1, 2014
Paul | July 16, 2014
57 Reviews | 878 Orders
$26.00
$105.00
