RapidStencil Simple. The fastest, easiest and most cost-effective solder paste stencil printer for prototyping and small production batches
Designed by Gyro_Gearloose_Store in United States of America
What is it? Introducing RapidStencil Simple, the fastest, easiest and most cost-effective solder paste stencil printer for prototyping and small production batches Why did you make it? You've spent c…
Read More…Introducing RapidStencil Simple, the fastest, easiest and most cost-effective solder paste stencil printer for prototyping and small production batches
You've spent countless hours soldering all of those SMD components on your latest prototypes or small production batches. We feel your pain. These tiny components are more difficult to solder by hand -- and if you find yourself with more than a few prototypes to assemble -- you've searched for a more efficient way to get those components on your board and most likely are already using solder paste stenciling.
RapidStencil is our specially designed product and method to manually apply solder paste to PCBs – accurately and repeatedly. RapidStencil aligns your PCB and stencil, so you can apply solder paste quickly and efficiently.
Solder paste printing made easy. RapidStencil has 4 bands of holes. The inner top and bottom bands (abcd, wxyz) have smaller holes used to align RapidStencil with the PCB. The outer top and bottom bands (ABCD, WXYZ) have larger holes used to align RapidStencil with the stencil. Special metal pins are provided to keep everything together.
Accurate, fast, repeatable results. RapidStencil perfectly aligns your PCB and stencil so you can finally eliminate printing defects and board failures. For even more support, you can glue 3 RapidStencil together. Additionally, the smaller PCB pins will not protrude over the stencil, making applying solder paste a breeze.
Two RapidStencil Sizes. Choose from our nominal 10x10 size for common 10x10 cm PCBs or our nominal 20x20 size for larger boards. These are nominal sizes, so they can take 20% bigger PCBs. The specifications are listed in our FAQ. [NOTE: YOU CAN SELECT EITHER 10X10 OR 20X20 SIZE AS AN OPTION].
Two RapidStencil Designs. Choose from our simple or advanced system. The simple system relies on you lifting up the stencil, while the advanced system has spring loaded pins soldered in its corners to help you lift the stencil accurately. While your hand is all that’s required to keep the stencil down, our advanced system includes some weights to make the process even easier. [NOTE: THIS LISTING IS FOR OUR SIMPLE SYSTEM. FOR INFORMATION ABOUT OUR ADVANCED SYSTEM, PLEASE SEE OUR OTHER LISTING].
Each RapidStencil is manufactured out of FR4 Standard Tg 130-140C.
Enter your email address if you'd like to be notified when RapidStencil 'Simple' Solder Paste Printer can be shipped to you:
$109.99
$4.97 $9.95
$5.47 $10.95
$5.47 $10.95
