A new design PCB for the Nintendo Entertainment System with new features. Bare PCB set with Digikey parts list
Designed by Low Budget in United States of America
Parts kits now in stock Digikey parts list has been updated 12/1/24 and is available to download in .xlsx format. Assembly guide available to download in .rtf format. Upgrade and/or repair your 30+ y…
Read More…Digikey parts list has been updated 12/1/24 and is available to download in .xlsx format. Assembly guide available to download in .rtf format.
Upgrade and/or repair your 30+ year old Nintendo NES with this new design motherboard.
The NESessity is a top quality replacement motherboard for your front loader NES console with a variety of new features and easy customization options. Circuit is based on a complete reverse engineering of the original system and uses the original CPU and PPU chips for 100% pixel prefect gameplay and compatibility. Designed for easy assembly, all components are through hole (with the exception of two SOIC chips.)
3 circuit boards are included, the NESessity v1.5 motherboard and two versions of the A/V + power board. One has composite video only and the other has RGB, s-video, and composite connectors. RGB and s-video output is only available when building the NESessity with the NESRGB add on.
CPU and PPU chips are required to be de-soldered and removed from the original NES. Aftermarket clone chips are readily available from Aliexpress and can also be used (although these will have sound issues and are not compatible with some games.)
The NESessity is designed to install in NTSC systems. Building a PAL compatible system is possible by using the correct PAL CPU (RP2A07) and PPU (RP2C07) chips along with a 26.601712 MHz crystal.
Famicom games can be played by using a readily available cartridge adapter.
Assembly / Usage Notes:
Enter your email address if you'd like to be notified when NESessity v1.6 Replacement PCB for NES Console can be shipped to you:
Documentation: (4.67)
Shipping: (4.08)
Benjamin | Aug. 24, 2024
Joel | Aug. 26, 2023
Eric | Feb. 8, 2023
Tracy | Dec. 27, 2022
Daniel | July 31, 2022
Jason | June 9, 2022
Chris | April 18, 2022
Miguel | Dec. 8, 2021
Lars | Oct. 29, 2021
Steven | Sept. 30, 2021
Robert | Dec. 2, 2020
Jonny | Oct. 13, 2020
28 Reviews | 1,292 Orders
$159.00
$189.00
