ESP32 audio development board with TAS5805M I2S DAC, driving 2x 23W load (8Ω, 1% THD+N)
Designed by Sonocotta in PolandNo shipping info available.
Availability The new batch (including both built-in and external antenna versions) is coming from the factory and should be in stock by early January. Alternatively, an antenna-less version is availa…
Read More…The new batch (including both built-in and external antenna versions) is coming from the factory and should be in stock by early January. Alternatively, an antenna-less version is available through the partner reseller.
Louder-ESP32 combines ubiquitous ESP32 with an I2S DAC with built-in D-class amplifier capable of driving full-size speakers. This combination provides your compact ESP32 module with the necessary memory and RAM capabilities to develop Hi-Fi products.
I spent the last few years developing different solutions based on ESP devices. It all started with ESP8266, where CPU power is not really sufficient to do real-time decoding, so you're limited to a rather simple ding-dong business. Then ESP32 came, bringing two much more capable cores, so you have a powerhouse to handle communication and decoding at the same time. Perhaps most importantly it also came with SPIRAM, so you can do decent buffering (essential for streamed content). Now new ESP32 C-Series and S-Series chips are entering the market, and their potential is mostly unrealized as of today.
I created ESP32 Audio docks and subsequently development boards, to be able to quickly prototype for the whole range of ESP8266 and ESP32 chips, starting with the simplest finger-sized toys and going all the way up to full-sized speakers.
Recently I went a rabbit hole of Home Assistant integrations and discovered different ways ESP32 with a decent DAC can be integrated into complex Home setups.
Audio streaming requires proper buffering to work, even with ESP32 500K of RAM it is a challenging task. For that reason, most of the projects will require WROVER modules that have onboard PSRAM chips. All ESP32 Audio boards have an 8MB PSRAM chip onboard, connected via a high-speed interface. Any code using PSRAM with just work out-of-the box.
HiFi-ESP32 | HiFi-ESP32S3 | Loud-ESP32 | Loud-ESP32S3 | Louder-ESP32 | Louder-ESP32S3 | |
MCU | ESP32-WROVER-N16R8 | ESP32-S3-WROOM-N16R8 | ESP32-WROVER-N16R8 | ESP32-S3-WROOM-N16R8 | ESP32-WROVER-N16R8 | ESP32-S3-WROOM-N16R8 |
DAC | PCM5100A 32bit Stereo DAC -100 dB typical noise level | PCM5100A 32bit Stereo DAC -100 dB typical noise level | Dual I2S DAC (MAX98357) with built in D-Class amp | Dual I2S DAC (MAX98357) with built in D-Class amp | Stereo I2S DAC (TAS5805M) with built in D-Class amp | Stereo I2S DAC (TAS5805M) with built in D-Class amp |
Output (4Ω) | Non-amplified stereo output, 2.1V RMS | Non-amplified stereo output, 2.1V RMS | 2x 5W | 2x 5W | 2x 32W (4Ω, 1% THD+N) | 2x 32W (4Ω, 1% THD+N) |
Output (8Ω) | Non-amplified stereo output | Non-amplified stereo output | 2x 3W | 2x 3W | 2x 22W (8Ω, 1% THD+N) | 2x 22W (8Ω, 1% THD+N) |
PSRAM | 8MB PSRAM (4MB usable) over 40MHz SPI | 8MB PSRAM over 80MHz QSPI | 8MB PSRAM (4MB usable) over 40MHz SPI | 8MB PSRAM over 80MHz QSPI | 8MB PSRAM (4MB usable) over 40MHz SPI | 8MB PSRAM over 80MHz QSPI |
Power | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section | 5V over USB-C, 2x LP5907 3.3 V Ultra-Low-Noise LDO for analog section | 5V (up to 2.5A) from USB-C | 5V (up to 2.5A) from USB-C | Up to 26V from external PSU 5V over USB-C with power limited to 2x5W | Up to 26V from external PSU 5V over USB-C with power limited to 2x5W |
Connectivity | WiFi + BT4.2 + BLE W5500 Ethernet (optional module) | WiFi + BLE W5500 Ethernet (optional module) | WiFi + BT4.2 + BLE W5500 Ethernet (optional module) | WiFi + BLE W5500 Ethernet (optional module) | WiFi + BT4.2 + BLE W5500 Ethernet (optional module) | WiFi + BLE W5500 Ethernet (optional module) |
I2S CLK | I2S DATA | I2S WS | PSRAM RESERVED | TAS5805 SDA | TAS5805 SCL | TAS5805 PWDN | TAS5805 FAULT | |
ESP32 | 26 | 22 | 25 | 16, 1 | 21 | 27 | 33 | 34 |
ESP32-S3 | 14 | 16 | 15 | 35, 36, 37 | 8 | 9 | 17 | 18 |
SPI CLK | SPI MOSI | SPI MISO | SPI CS | SPI HOST/SPEED | ETH INT | ETH RST | |
ESP32 | 18 | 23 | 19 | 05 | 2/20MHz | 35 | 14 |
ESP32-S3 | 12 | 11 | 13 | 10 | SPI2/20MHz | 6 | 5 |
IR IN | RGB OUT | OLED SPI HOST/SPEED | OLED SPI CLK | OLED SPI MOSI | OLED SPI MISO | OLED SPI CS | OLED SPI DC | OLED RST | |
ESP32 | 39 | 12 | 2/20MHz | 18 | 23 | 19 | 15 | 4 | 32 |
ESP32-S3 | 7 | 9 | SPI2/20MHz | 12 | 11 | 13 | 39 | (37) | 38 |
and Upload
Follow the ESP8266Audio library guide. Default settings will work out of the box with ESP8266 and ESP32 boards. For ESP32C3 and ESP32S2 board please adjust the pinout according to the above section
Few words of explanation.
media_player
Squeezelite-ESP32 is a multimedia software suite, that started as a renderer (or player) of LMS (Logitech Media Server). Now it is extended with - Spotify over-the-air player using SpotifyConnect (thanks to cspot) - AirPlay controller (iPhone, iTunes ...) and enjoy synchronization multiroom as well (although it's AirPlay 1 only) - Traditional Bluetooth device (iPhone, Android)
And LMS itself - Streams your local music and connects to all major online music providers (Spotify, Deezer, Tidal, Qobuz) using Logitech Media Server - a.k.a LMS with multi-room audio synchronization. - LMS can be extended by numerous plugins and can be controlled using a Web browser or dedicated applications (iPhone, Android). - It can also send audio to UPnP, Sonos, Chromecast, and AirPlay speakers/devices.
All ESP32-based boards are tested with Squeezelite-ESP32 software, which can be flashed using nothing but a web browser. You can use Squeezelite-ESP32 installer for that purpose.
Connect the device to the USB port and select it from the list | |
Exit recovery |
You can use it now
Please visit the hardware section for board schematics and PCB designs. Note that PCBs are shared as multi-layer PDFs.
Image |
Every board has a header that allows to solder in W5500 SPI Ethernet module that is very easy to find. The only downside is that with the module installed board will not fit the case, unless it is cut to accomodate extra height.
HiFi-ESP32(S3) | Louder-ESP32(S3) |
image coming soon... |
TAS5805M DAC Allows 2 modes of operation - BTL (stereo) and PBTL (parallel, or mono). In Mono amp will use a completely different modulation scheme and basically will fully synchronize output drivers. Jumpers on the board allow both output drivers to connect to the same speaker. The most important step is to inform the Amp to change modulation in the first place via I2C comman. In the case of sqeezelite DAC controls set value is the following:
dac_controlset: {"init":[{"reg":3,"val":2},{"reg":3,"val":3},{"reg":2,"val":4}],"poweron":[{"reg":3,"val":3}],"poweroff":[{"reg":3,"val":0}]}
compared to default: dac_controlset: {"init":[{"reg":3,"val":2},{"reg":3,"val":3}],"poweron":[{"reg":3,"val":3}],"poweroff":[{"reg":3,"val":0}]}
One can test audio with a single speaker connected between L and R terminals (plus on one side and minus on the other). Optionally, jumpers on the board will effectively connect the second driver in parallel doubling the current capability.
Important point, this will send only one channel to the output, that’s just how the DAC works. True mono as (L+R)/2 is possible via more in-depth configuration (very poorly documented), but I haven’t managed to configure that on the stand. I’m still working on that. (Along with a few more really cool DSP features that this DAC has, like EQ, subwoofer mode and tone compensation settings)
BTL | PBTL | |
Descriotion | Bridge Tied Load, Stereo | Parallel Bridge Tied Load, Mono |
Rated Power | 2×23W (8-Ω, 21 V, THD+N=1%) | 45W (4-Ω, 21 V, THD+N=1%) |
Schematics | ||
Speaker Connection |
Starting from Rev E, an additional header is exposed to allow datasheet-specced connectivity
Image | Legend |
Stereo Mode - leave open | |
Mono (PBTL) Mode, close horisontally |
The TAS5805M DAC has a very powerful DSP, that allows doing lots of data processing on the silicon, that otherwise would take a considerable part of your CPU time. As of the moment of writing it is mostly an undiscovered part of the DAC, since unfortunately, TI is not making it very easy for developers. (A minute of complaint) To be more specific, you need to be (A) a proven hardware manufacturer to get access to the configuration software, namely PurePath. (B) you need to apply for a personal license and go through an approval process, and after a few weeks of waiting you get access to one DAC configuration you asked for. (C) You find out that it will work with TI's own evaluation board that will set you back $250 if you'd be able to find one. Otherwise, all you have is a list of I2C commands that you need to transfer to the device on your own cost. No wonder no one knows how to use it.
But moanings aside, what do you get after:
At this moment it is very experimental. In the perfect world, you should be able to adjust all of those settings to make your speaker-enclosure setup work the best it can, and even apply your room factors into the equation. But with above disclaimer I can only deliver limited set of configurations corresponding to the most common use cases:
All of the above are available right now for experimentation. I'm keen to hear your feedback while I moving forward with porting this to other software options
Barrel jack used is spaced at 6mm hole/2mm pin, which is typically 5.5/2.5mm jack on the male side.
The screw terminal is connected parallel to the barrel jack, you can use either interchangeably.
The power adapter specs depend on the speaker you're planning to use. DAC efficiency is close to 100%, so just take the power rating of your speaker (say 2x10w), and impedance (say 8 ohms) and you'd need at least 9 volts rated at 1.2 amps per channel, round up to 3 total amps.
It is not recommended to go beyond the voltage your speakers can take, otherwise amp will blow your speakers in no time.
Important: do not connect Vin and USB-C at the same time, or you will cook your USB-C port! I didn't want to lose voltage on the voltage-select circuit, so these two sources are connected. While developing and debugging, a USB-C power source will be sufficient to run DAC with a power limit of ~5W per channel.
HiFi-ESP32(S3), Loud-ESP32(S3) and Louder-ESP32(S3) are mechanically compatible with Raspberry Pi 3/4 cases, tested with transparent ones. Also, community members created a few 3-D printable designs that can be found here and here
Louder-ESP32 |
Enter your email address if you'd like to be notified when Louder ESP32 can be shipped to you:
Currently, Poczta Polska does not ship to Israel, and a few more countries due to a lack of airline operations. As soon as they will lift the restrictions, I'll restore shipments.
Product: (4.88)
Documentation: (4.38)
Shipping: (4.50)
Communication: (4.75)
Arnaud | Dec. 27, 2024
Oyvind | Nov. 2, 2024
Miguel | Oct. 30, 2024
Fabian | Sept. 11, 2024
Erik | Aug. 13, 2024
Adrian | March 13, 2024
Dustin | Jan. 31, 2024
Maickel | Dec. 30, 2023
