9 to 20 Channel Light Show Xmas Sequencer Chaser Controller for Incandescent Lamp & LED - HomLiCon RCL164R
Designed by mc_kit in BulgariaNo shipping info available.
9 to 20 Channel Light Show Controller - HomLiCon RCL164R Designed to control dynamic illuminated advertising signs, spectacular light walls, podiums, etc. Number of channels used can be adjusted f…
Read More…Designed to control dynamic illuminated advertising signs, spectacular light walls, podiums, etc.
Technical Specifications | |
Number of active channels: | 9 - 20 |
Supply voltage | 200-240V/50Hz or 110-130V/60Hz |
Number of levels for each channel | 120 (50Hz) or 110 (60Hz) |
Ambient temperature | 5 - 40°C |
Dimensions LC21R | 100 x 100 x 30 mm |
Dimensions Remote | 85 x 40 x 7 mm |
Number of channels 120/230V | 16 |
Maximum output current per channel | 0.5A |
Maximum output power per channel | 60W(120 V) or 110W(230 V) |
Maximum total output current | 8A |
Number of channels 12V | 4 |
Supply voltage | 5-16V DC (by an ext. PSU) |
Maximum output current per channel | 2A |
Enter your email address if you'd like to be notified when 20 Channel Light Show Controller-HomLiCon RCL164R can be shipped to you:
$79.00
$88.00
$42.00
$54.00
$42.00
$79.00
$88.00
