Color Organ, Level Meter, Chaser, Sound Music Light Show, LED Controller PWM 5 Channel – HomLiCon LCH5
5 Channel Multifunctional PWM Controller with Remote Control – HomLiCon LCH5 Designed to control groups LED, relays, small motors, fans, PC mod, control models, home automation. Three main modes: • …
Read More…Designed to control groups LED, relays, small motors, fans, PC mod, control models, home automation.
Technical Specifications | |
Number of Channels | 5 |
Color organ number of channels | 4 + Inverse Channel |
Light Show Number of Channels | 4 + Backlight Channel |
Supply voltage | 12V (9−16V) DC |
Maximum output current per channel | 2A |
Maximum total output current | 10A |
PWM steps for each channel | 110 |
Color Organ bandwidth | LF 50−200Hz , MLF 200Hz−1kHz , MHF 1−7kHz, HF 7−14kHz |
Line-in Nominal level (set standard / high sensitivity) | 0.3V / 0.15V RMS |
Mic-in range of sound level | 60-120dB |
Dimensions LCH5 | 75 x 49 x 20 mm |
Dimensions Remote | 90 x 40 x 10 mm |
USER VIDEOS PLAYLIST , User video 1
Some of the elements may differ in shape and color from the pictures in the listing. The terminal blocks may be blue, green or black.
International orders may be subject to duties, taxes, import fees, etc. These fees are not included in the price of the products, or the order total. These fees are the sole responsibility of the buyer.
Enter your email address if you'd like to be notified when Color Organ 5 Channel PWM Controller HomLiCon LCH5 can be shipped to you:
1 | $54.00 |
2-3 | $52.00 |
4+ | $49.00 |
$79.00
$88.00
$42.00
$47.00
$42.00
$79.00
$88.00
