Color Organ, Level Meter, Chaser, Sound Music Light Show, LED Controller PWM 5 Channel – HomLiCon LCH5T - DIY Kit
5 Channel Multifunctional PWM Controller with Remote Control – HomLiCon LCH5T Designed to control groups LED, relays, small motors, fans, PC mod, control models, home automation. Three main modes: •…
Read More…Designed to control groups LED, relays, small motors, fans, PC mod, control models, home automation.
Technical Specifications | |
Number of Channels | 5 |
Color organ number of channels | 4 + Inverse Channel |
Light Show Number of Channels | 4 + Backlight Channel |
Supply voltage | 12V (9−28V) DC |
Maximum output current per channel | 4A |
Maximum total output current | 20A |
PWM steps for each channel | 110 |
Color Organ bandwidth | LF 50−200Hz , MLF 200Hz−1kHz , MHF 1−7kHz, HF 7−14kHz |
Line-in Nominal level (set standard / high sensitivity) | 0.3V / 0.15V RMS |
Mic-in range of sound level | 60-120dB (with module MACL - optional) |
Dimensions LCH5T V1 | 75 x 48 x 20 mm |
Dimensions LCH5T V2 | 57 x 49 x 20 mm |
Dimensions Remote | 85 x 40 x 7 mm |
USER VIDEOS PLAYLIST , User video 1
Enter your email address if you'd like to be notified when Color Organ 5 Channel PWM Controller LCH5T can be shipped to you:
1 | $42.00 |
2 | $38.00 |
3 | $37.00 |
4+ | $36.00 |
Documentation: (4.33)
Shipping: (4.67)
Alexey | March 11, 2025
John | Oct. 2, 2023
Stefan | July 19, 2021
Terry | Nov. 16, 2019
Henrik | Oct. 30, 2019
Craig | Aug. 13, 2019
$89.00
$79.00
$79.00
$88.00
$54.00
