Color Organ, Sound Activated Light Show, Chaser, Sequencer, Dimmer, Strobe, AC 120/230V 2000W - HomLiCon LCH4HV2
4 Channel Multifunctional Controller with Remote Control HomLiCon LCH4HV2 Controller Features Three main modes: • Color Organ,Sound Activated Light Show • , • Light Sequencer • , • Lighting • Co…
Read More…Three main modes: • Color Organ,Sound Activated Light Show • , • Light Sequencer • , • Lighting •
Control of 4 channels with groups of the following types of lamps: • Incandescent lamps • , • Halogen lamps • , • Dimmable LED lamps / Dimmable LED strips •
Control of all settings and functions through the remote control included in the kit.
LCH4HV2_1200W / LCH4HV2_2000W | |
Number of Channels | 4 |
Mains supply voltage | 90 – 240 VAC |
Maximum output power total (120V mains voltage) | 1200W/2000 W |
Maximum output power total (230V mains voltage) | 2400W/4000W |
Maximum output power per channel (120V mains voltage) | 300W/500 W |
Maximum output power per channel (230V mains voltage) | 600W/1000W |
Maximum output current per channel | 2.5 A / 4 A |
Maximum output current total | 10 A / 16 A |
Phase control steps for each channel | 110 |
Supply voltage optically isolated part | 12 VDC (9 – 12 VDC) |
Current consumption | 50 mA |
Color Organ bandwidths | LF 50−200Hz , MF 200Hz−7kHz, HF 7−14kHz |
Line-in nominal level (set standard / high sensitivity) | 0.3V / 0.15V RMS |
Mic-in range of sound level (with module MACL - optional) | 60-120dB |
Dimensions LCH4HV2 | 125 / 113 / 35 mm |
Dimensions Remote | 90 / 40 / 10 mm |
Ambient temperature | 5 − 40°C |
Video 1 - HomLiCon LCH3HV - Incandescent Lamps
Video 2 - HomLiCon LCH3HV - LED COB
International orders may be subject to duties, taxes, import fees, etc. These fees are not included in the price of the products, or the order total. These fees are the sole responsibility of the buyer.
Enter your email address if you'd like to be notified when Color Organ Dimmer Chaser Music to Light 4Ch AC can be shipped to you:
$79.00
$88.00
$42.00
$54.00
$42.00
$79.00
$88.00
