Color Organ, Level Meter, Chaser, Sound Music Light Show, LED Controller PWM 4 Channel – HomLiCon LCH4F
4 Channel Multifunctional PWM Controller with Remote Control – HomLiCon LCH4F Designed to control groups LED, relays, small motors, fans, PC mod, control models, home automation. Easily switch betwe…
Read More…Designed to control groups LED, relays, small motors, fans, PC mod, control models, home automation.
Technical Specifications | |
Number of Channels | 4 |
Supply voltage | 12V DC (8−16V DC) |
Maximum output current per channel | 2A |
Maximum total output current | 8A |
PWM steps for each channel | 110 |
Color Organ bandwidth | LF 50−200Hz , MLF 200Hz−1kHz , MHF 1−7kHz, HF 7−14kHz |
Line-in Nominal level | 0.3V / 0.15V RMS |
Mic-in range of sound level | 60-120dB |
Dimensions LCH4F | 75 x 43 x 20 mm |
Dimensions Remote | 85 x 40 x 7 mm |
USER VIDEOS PLAYLIST , User video 1
Enter your email address if you'd like to be notified when Color Organ, LED Sequencer - HomLiCon LCH4F can be shipped to you:
1 | $49.00 |
2-3 | $47.00 |
4+ | $45.00 |
$79.00
$88.00
$42.00
$54.00
$42.00
$79.00
$88.00
