Color Organ, LED Sound Activated Light Show, Sequencer, Chaser - HomLiCon LCH3B
3 Channel LED PWM Controller – HomLiCon LCH3B Designed to control groups LED, LEDs strips, LED modules. Automatic color organ with digital division of the bandwidth in 3 range: LF 50 - 200Hz , MF 2…
Read More…Designed to control groups LED, LEDs strips, LED modules.
Technical Specifications | |
Number of Channels | 3 |
Supply voltage | 8−16V DC |
Maximum output current per channel | 2A |
Maximum total output current | 6A |
PWM steps for each channel | 110 |
Color Organ bandwidths | LF 50−200Hz , MF 200Hz−7kHz, HF 7−14kHz |
Line-in Nominal level | 0.3V / 0.15V RMS |
Mic-in range of sound level (with module MACL - optional) | 60-120dB |
Dimensions LCH3B | 32 x 48 x 12 mm |
Enter your email address if you'd like to be notified when Color Organ, LED Sound Light Show - HomLiCon LCH3B can be shipped to you:
1 | $34.00 |
2-3 | $31.00 |
4+ | $29.00 |
$79.00
$88.00
$42.00
$54.00
$47.00
$79.00
$88.00
$123.00
